ANN: rtems-4.10-gcc upgraded to 4.4.6
Gedare Bloom gedare at gwmail.gwu.edu
Tue Jun 21 17:57:57 UTC 2011
On Tue, Jun 21, 2011 at 10:56 AM, kfeng <feng at bnl.gov> wrote:
> On 04/22/2011 12:00 AM, Ralf Corsepius wrote:
>> Hi,
>> The subject says all:
>> The rtems-4.10-gcc packages have been upgraded to FSF gcc-4.4.6.
>> This upgrade is supposed to be a minor "bug-fix only" upgrade, which
>> should not cause any major troubles to users.
> The pre-built RPM tools, which includes gcc-4.4.6 works very well. I have
> tested it successfully
> with the mvme5500 BSP. I would be so happy if I could just use it forever.
> However, here is a
> Ubuntu PC, which requires on to build the tools.  I am not sure if all the
> *.diff listed
> at  ftp/pub/rtems/SOURCES/4.10/ have to be applied.  The 4.10 CVS head at
> rtems/contrib/crossrpms/patches lists only a few, but it even includes a
> patch
> from gcc-4.4.5.  I got all sorts of different errors in building the tools
> by playing guessing games.
> I did successfully build the tools for gcc-4.4.5 , but I understand that
> there are known bugs.
> Could you verify the required patches for building ,gcc4.4.6 please ?
You should only have to apply the most recent patch, i.e. they are not
incremental. I guess for 4.10.1 these would be:
binutils-2.20.1-rtems4.10-20100826.diff
gcc-core-4.4.6-rtems4.10-20110420.diff
newlib-1.18.0-rtems4.10-20110518.diff
> Regards,
> Kate Feng
>> Ralf
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
