RTEMS shell: pthread priorities printed out as rtems priorities
Mon Jun 27 15:01:49 UTC 2011
On 06/27/2011 03:11 AM, Chris Johns wrote:
> On 27/06/11 3:11 AM, Peter Dufault wrote:
>> The RTEMS shell will print out the pthread priorities as what I assume are classic RTEMS task priorities, where lower means higher priority instead of the POSIX priority where a higher number is higher priority.  It caused me a moment of confusion.
>> I think it should print out the same POSIX priorities you assigned the tasks with the POSIX interface.  Thoughts?
> Maybe the kernel priority (which is the classic priority) and the API
> priority should be shown. A system can have a mix of class and POSIX and
> handling these differences could also be confusing.
It is indeed confusing and this sounds line the way to handle it.
Which command are we talking about?
> Chris
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D.             Director of Research&  Development
