NULL call to _Workspace_Free() via _Objects_Extend_information at startup
Peter Dufault dufault at hda.com
Tue Mar 1 00:25:17 UTC 2011
On Feb 28, 2011, at 7:16 , Chris Johns wrote:
> It will be ignored just like 'free'. We will just use the 'in heap call'
> to do this. Treating NULL as a special case has meant the bugs where
> hidden and if a non-NULL bad pointer is passed in no protection to the
> user is provided.
If the change is in _Heap_Free() you'll want to formally redefine it to ignore NULL.  It currently isn't defined that way:
Frees the allocated memory area starting at addr in the heap heap.
Inappropriate values for addr may corrupt the heap.
Returns true in case of success, and false otherwise.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
