Problem in using PPP & Ethernet Interface, together, with TCP/IP
Mon Mar 7 07:24:01 UTC 2011
Hi,
can you please add the loop back interface and try our test again?  In RTEMS
4.9.4 you can add the loop back interface like this:
int rtems_bsdnet_loopattach(struct rtems_bsdnet_ifconfig *, int);
static struct rtems_bsdnet_ifconfig loopback_config = {
    "lo0",                          /* name */
    rtems_bsdnet_loopattach,        /* attach function */
    NULL,                           /* link to next interface */
    "127.0.0.1",                    /* IP address */
    "255.0.0.0",                    /* IP net mask */
Have a nice day!
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
