Question on FAT Code
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Mar 14 21:36:42 UTC 2011
Hi,
Coverity (#183) reported an issue in
cpukit/libfs/src/dosfs/msdos_format.c.
Th
1081 case FAT_FAT16:
1082 /* FAT entry 0: 0xff00|media_type */
Event result_independent_of_operands: (0xff00 | fmt_params.media_code)
>> 8 is 0xff regardless of the values of its operands [non-specific
operand of assignment].
1083 FAT_SET_VAL16(tmp_sec,0,0xff00|fmt_params.media_code);
Looking at the definition of FAT_SET_VAL16(),
I can see what it doesn't like.
#define FAT_SET_VAL16(x, ofs,val) do { \
FAT_SET_VAL8((x),(ofs),(val)); \
FAT_SET_VAL8((x),(ofs)+1,(val)>>8);\
} while (0)
In the case of line 1083, offset 1 is always 0xff.
Would this code better written as?
FAT_SET_VAL8(tmp_sec,0,fmt_params.media_code);
FAT_SET_VAL8(tmp_sec,1,0xff);
It avoids the evaluation to a constant for offset 1.
I know this is picky but the Coverity Scanner is correct
that offset 1 is always 0xff and we have written something
complicated to produce that.
Comments?
Joel Sherrill, Ph.D. Director of Research& Development
