Problems building Gaisler's RTEMS 4.8 on Ubuntu x86_64
Tue Mar 15 21:06:51 UTC 2011
On 03/15/2011 04:01 PM, Gerard wrote:
> I'm trying to set up the Gaisler toolchain for rtems 4.8.
> The OS is Ubuntu Linux 10.10, the architecture is X86 64 bits.
You should stick to an older OS or a newer RTEMS. :-D
But you definitely need to stick EXACTLY to the
autoconf and automake versions.
> I'm having some trouble trying to recompile the RTEMS source package
> for a LEON3 computer.
> These are the Gaisler packages that I'm using:
> Toolchain :  sparc-rtems-4.8-gcc-4.2.4-1.1.2-linux.tar.bz2
> Source: rtems-4.8-1.1.2-src.tar.bz2
> I'm using GNU Autoconf ver. 2.63, and GNU Automake ver. 1.10.2 .
I believe 2.61 was the last autoconf for 4.8. and 1.10
was for automake.
> I had to install the package libc6-dev-i386 in order to run the
> compiler and the rest toolchain executables.
> After installing that package I was able to successfully run the
> following steps of the recompilation process:
> # cd /usr/rtems-4.8/src
> # make veryclean
> # make bootstrap
> # make configure
> After that, "make compile" fails like this:
> configure: configuring in ../../cpukit
> configure: running /bin/bash
> '/opt/rtems-4.8/src/rtems-4.8/c/src/../../cpukit/configure'
> '--prefix=/opt/rtems-4.8' '--host=sparc-rtems'
> '--build=x86_64-unknown-linux-gnu' '--target=sparc-rtems'
> '--disable-itron' '--disable-tests' '--enable-cxx' '--disable-docs'
> '--with-target-subdir=sparc-rtems'
> '--exec-prefix=/opt/rtems-4.8/sparc-rtems'
> '--includedir=/opt/rtems-4.8/sparc-rtems/include'
> 'build_alias=x86_64-unknown-linux-gnu' 'host_alias=sparc-rtems'
> 'target_alias=sparc-rtems' '--with-project-root=../../'
> '--with-project-top=../../' 'RTEMS_BSP=leon3' 'RTEMS_CPU_MODEL=leon3'
> 'RTEMS_BSP_FAMILY=leon3' 'CFLAGS=-mcpu=cypress -msoft-float -O2 -g'
> '--with-project-root=../../../leon3/'
> '--includedir=/opt/rtems-4.8/sparc-rtems/leon3/lib/include'
> '--libdir=/opt/rtems-4.8/sparc-rtems/leon3/lib'
> --cache-file=/dev/null
> --srcdir=/opt/rtems-4.8/src/rtems-4.8/c/src/../../cpukit
> configure: WARNING: unrecognized options: --disable-tests,
> --enable-cxx, --disable-docs, --with-target-subdir, --with-project-top
> checking for gmake... no
> checking for make... make
> checking build system type... x86_64-unknown-linux-gnu
> checking host system type... sparc-unknown-rtems
> checking rtems target cpu... sparc
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for sparc-rtems-strip... sparc-rtems-strip
> checking for a thread-safe mkdir -p... /bin/mkdir -p
> checking for gawk... gawk
> checking whether make sets $(MAKE)... yes
> checking whether to enable maintainer-specific portions of Makefiles... no
> /opt/rtems-4.8/src/rtems-4.8/c/src/../../cpukit/configure: line 3355:
> syntax error near unexpected token `;'
> /opt/rtems-4.8/src/rtems-4.8/c/src/../../cpukit/configure: line 3355: `; then :'
> configure: error: /bin/bash
> '/opt/rtems-4.8/src/rtems-4.8/c/src/../../cpukit/configure' failed for
> ../../cpukit
> make[3]: *** [leon3] Error 1
> make[3]: Leaving directory `/opt/rtems-4.8/src/build/sparc-rtems/c'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/opt/rtems-4.8/src/build/sparc-rtems/c'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/opt/rtems-4.8/src/build'
> make: *** [compile] Error 2
> Line 3355 of the configure file in cpukit is in the middle of the
> following fragment:
> if test x"${enable_rtems_debug}" = x"yes"
> cat>>confdefs.h<<_ACEOF
> #define RTEMS_DEBUG 1
> _ACEOF
> ; then :
> fi
> Where the "then" doesn't seem to be in the right place.
> Has anyone seen anything like this before? Can it be that there are
> some dependencies missing? Maybe I should use some other version
> of autoconf/automake? Maybe some other package that I need to install?
> Thanks!
> Gerardo.-
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D.             Director of Research&  Development
