libboost and asio
Eric Norum wenorum at lbl.gov
Wed Mar 16 15:18:45 UTC 2011
I don't understand how that works.  How do the target-specific flags get passed on to the compiler?
For example, when I build an application for an RTEMS-mvme3100 target I see compiler flags like:
	powerpc-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme3100/lib/ -specs bsp_specs -qrtems -mcpu=powerpc -msoft-float
but if I build for an RTEMS-mvme2100 target I see
	powerpc-rtems4.10-g++ -B/usr/local/rtems/rtems-4.10/powerpc-rtems4.10/mvme2100/lib/ -specs bsp_specs -qrtems -mcpu=603e
So with the 'using' line shown below, what header files are used for building boost and for what CPU architecture are the objects built?
On Mar 16, 2011, at 12:41 AM, Sebastian Huber wrote:
> On 03/15/2011 09:42 PM, Eric Norum wrote:
>> Has anyone looked into proting the boost (http://www.boost.org/) and asio (http://think-async.com/) packages to RTEMS?
>> Merging the boost and RTEMS build systems looks like a lot of work -- I'm hoping that I'm mistaken in this, though.
>> Thanks,
> It was quite easy to build boost for RTEMS.  You have to modify the file:
> tools/build/v2/user-config.jam
> Use something like this:
> using gcc : 4.5.2 : powerpc-rtems4.11-g++ ;
> A lot of modules work well after minor modifications in the config header.  I
> use mainly the header only parts.
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> rtems-users mailing list
> rtems-users at rtems.org
Eric Norum
wenorum at lbl.gov
