GSOC2011 project RTEMS HyperVisor
张文杰
157724595 at 163.com
Mon Mar 21 12:31:31 UTC 2011
AIR/AIR IIseems that it hasimplemented ARINC 653 interface in RTEMS, but i do
not know if these implements is opened. If it is opened we also modify their work,
Because ARINC 653 interface should be based on Hypervisor architecture whereas
AIR implement is based on native RTEMS. XtratuM is a independent Hypervisor which
has nothing to do with other OS, but my thought is to add a Hypervisor to RTEMS. Just
reference the implement of XtratuM
At 2011-03-21 16:21:12,"Metge Jean-Jacques" <Jean-Jacques.Metge at cnes.fr> wrote:
Hi,
For my information, what do you exactly intend to do in the frame of this GSOC, that would not have been already done, either in the frame of AIR/AIR II or in the frame of XtratuM ?
Best regards
Jean-Jacques METGE
French Space Agency
De :rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]De la part de ???
Envoyé : dimanche 20 mars 2011 14:57
À : 张文杰
Cc : RTEMS Users
Objet : Re:GSOC2011 project RTEMS HyperVisor
Sorry for forgetting add the reference link.
[1]. http://www.rtems.com/wiki/index.php/RTEMSHyperVisor
[2]. http://air.di.fc.ul.pt/air/?Home
[3].http://www.xtratum.org/
[4]. http://www.helenos.org/
At 2011-03-20 21:50:39,"张文杰" <157724595 at 163.com> wrote:
Hi, all:
I am a student who is preparing for participating the GSOC2011 RTEMS. My interested project isRTEMS HyperVisor [1]. This
project ‘s ultimate goal is to make RTEMS support to run multiple operating systems(like Linux or uclinux) and meantime RTEMS can be
adapted to fullfill the requirements defined in the ARINC 653 standard. So the project is divided into two milestone tasks: 1) add a HyperVisor to RTEMS. the design of HyperVisor is compatible with ARINC 653 standard. 2). implement ARINC 653 interface in
RTEMS which can reference the a ESA project named AIR[2].
Hypervisor, also called virtual machine monitor (VMM), is one of virtualization techniqueswhich allow multiple operating systems.
For embedded systems it must have real-time capability. And there is also a challenge to the resource-constrained embedded
systems, becausesupport for virtualization requiresmemory protection (in the form of a memory management unit or at least a
memory protection unit) and a distinction between user mode and privileged mode, which rules out many microcontrollers. About the implement of HyperVisor for RTEMS there are two projects we can reference. First is project XtratuM [3] which is a small
native (bare-metal) hypervisor, now the RTEMS has been ported to XtratuM run as a guest OS and its design use ARINC 653 as
a reference although ARINC-653 is not directly applicable to the hypervisor systems. Another project is HelenOS operating
system [4] which is designed as a relatively small microkernel assisted with a set of userspace drivers and server tasks, Its kernel
is a good reference candidate for the design of Hypervisor.
This is just my initial thoughts, if there is any inappropriate please point out.Do not hesitate to add your comments.
Wenjie Zhang
Best Regards
URL: <http://lists.rtems.org/pipermail/users/attachments/20110321/9041927a/attachment.html>
