Willing to join GSoC2011 project "RTEMS port of the GNU Java Compiler (gjc)"
Ralf Corsepius ralf.corsepius at rtems.org
Mon Mar 28 13:56:06 UTC 2011
On 03/28/2011 03:41 PM, Joel Sherrill wrote:
> On 03/19/2011 09:17 PM, 刘杰 wrote:
> This means building and testing gcc. There are scripts in rtems-testing/
> which are used to test C, C++, Ada, and (preliminary) Objective-C on RTEMS.
> You will be augmenting those scripts and then fixing whatever is
> required in
> gcc to make GCJ work.
Dumb question: Is GCJ still alive?
Correct me if I am wrong, but to my knowledge, GCJ is in some kind of
hiatus, because most (all?) major GCC contributors are not using it anymore.
Ralf
