RTEMS with Skyeye
padmakumar at sigtechwireless.com padmakumar at sigtechwireless.com
Tue Mar 29 05:50:17 UTC 2011
Hi,
I have successfully build RTEMS 4.10 on Ubuntu 10.10.
When i tried to run the example code(hello.exe) on Skyeye , i am getting
the following error.
padmakumar at ubuntu:/opt/rtems-4.10/bin$ skyeye o-optimize/hello.exe
**************************** WARNING **********************************
If you want to run ELF image, you should use -e option to indicate
your elf-format image filename. Or you only want to run binary image,
you need to set the filename of the image and its entry in skyeye.conf.
Non-option argument o-optimize/hello.exe
Your elf file is little endian.
arch: arm
cpu info: armv4, arm720t, 41807200, ffffff00, 1
mach info: name ep7312, mach_init addr 0x806b800
log_info: log is on.
log_info:log file is /tmp/sk1.log, fd is 0x8c24238
log_info: log start clock 2000000
log_info: log end clock 300000
uart_mod:0, desc_in:, desc_out:, converter:
SKYEYE: use arm7100 mmu ops
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194302,
mem_read_word addr = 1000000 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194303,
mem_read_word addr = 1000004 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194304,
mem_read_word addr = 1000008 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194305,
mem_read_word addr = 100000c no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194306,
mem_read_word addr = 1000010 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194307,
mem_read_word addr = 1000014 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194308,
mem_read_word addr = 1000018 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194309,
mem_read_word addr = 100001c no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194310,
mem_read_word addr = 1000020 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194311,
mem_read_word addr = 1000024 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194312,
mem_read_word addr = 1000028 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194313,
mem_read_word addr = 100002c no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194314,
mem_read_word addr = 1000030 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194315,
mem_read_word addr = 1000034 no bank
SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194316,
mem_read_word addr = 1000038 no bank
Any suggestion would be highly appreciated.
Also my skyeye.conf file content is
cpu: arm720t
mach: ep7312
mem_bank: map=I,type=RW, addr=0x80000000, size=0x00100000
mem_bank: map=M, type=RW, addr=0x00000000, size=0x1000000
log: logon=1, logfile=/tmp/sk1.log, start=2000000, end=300000
Thanks in Advance,
Padmakumar
