RTEMS with Skyeye
Tue Mar 29 13:11:35 UTC 2011
On 03/29/2011 12:50 AM, padmakumar at sigtechwireless.com wrote:
> Hi,
> I have successfully build RTEMS 4.10 on Ubuntu 10.10.
> When i tried to run the example code(hello.exe) on Skyeye , i am getting
> the following error.
Which BSP?  Looks like edb7312?
> padmakumar at ubuntu:/opt/rtems-4.10/bin$ skyeye o-optimize/hello.exe
> **************************** WARNING **********************************
> If you want to run ELF image, you should use -e option to indicate
> your elf-format image filename. Or you only want to run binary image,
> you need to set the filename of the image and its entry in skyeye.conf.
I think the message says what the problem is.  You have to
provide a skyeye.conf and use a -e XXX.exe option.
You should check out the rtems-testing CVS module
and use the edb7312 script.
> Non-option argument o-optimize/hello.exe
> Your elf file is little endian.
> arch: arm
> cpu info: armv4, arm720t, 41807200, ffffff00, 1
> mach info: name ep7312, mach_init addr 0x806b800
> log_info: log is on.
> log_info:log file is /tmp/sk1.log, fd is 0x8c24238
> log_info: log start clock 2000000
> log_info: log end clock 300000
> uart_mod:0, desc_in:, desc_out:, converter:
> SKYEYE: use arm7100 mmu ops
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194302,
> mem_read_word addr = 1000000 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194303,
> mem_read_word addr = 1000004 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194304,
> mem_read_word addr = 1000008 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194305,
> mem_read_word addr = 100000c no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194306,
> mem_read_word addr = 1000010 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194307,
> mem_read_word addr = 1000014 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194308,
> mem_read_word addr = 1000018 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194309,
> mem_read_word addr = 100001c no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194310,
> mem_read_word addr = 1000020 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194311,
> mem_read_word addr = 1000024 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194312,
> mem_read_word addr = 1000028 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194313,
> mem_read_word addr = 100002c no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194314,
> mem_read_word addr = 1000030 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194315,
> mem_read_word addr = 1000034 no bank
> SKYEYE:Error in mem_read_word, no bank found, NumInstrs 4194316,
> mem_read_word addr = 1000038 no bank
> Any suggestion would be highly appreciated.
> Also my skyeye.conf file content is
> cpu: arm720t
> mach: ep7312
> mem_bank: map=I,type=RW, addr=0x80000000, size=0x00100000
> mem_bank: map=M, type=RW, addr=0x00000000, size=0x1000000
> log: logon=1, logfile=/tmp/sk1.log, start=2000000, end=300000
> Thanks in Advance,
> Padmakumar
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D.             Director of Research&  Development
