Problem in using PPP & Ethernet Interface, together, with TCP/IP
Tue Mar 1 09:05:55 UTC 2011
On 03/01/2011 09:54 AM, Shah, Viral wrote:
> struct rtems_bsdnet_config rtems_bsdnet_config =
>     &ppp_netdriver_config,
>     &eth_netdriver_config,
>     NULL,               /* BOOTP */
The above is completely wrong.  Turn on the warnings.  You should remove the
"&ppp_netdriver_config," line.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
