gdb+qemu+rtems: Problem #2 in offset computation
Mon Mar 7 12:14:38 UTC 2011
There are (were) five reasons the timer calibation could fail on pc386. It did appear to happen in qemu and not on real hardware and in qemu inside a vm more than just qemu. It is something to do with the simulated timer jumping.  I doubt changing the amount of memory helps. It is rather random. Run again and it may not happen.
FWIW I committed a fix to the head where if it hits this situation, it will retry five times before locking up. Should help. Maybe I should apply this to the release branches.
--joel
Domenico Di Leo <domenico.dileo at unina.it> wrote:
>Hi
>I have experienced the same problem.
>My solution was really simple, since I started RTMES with qemu (on a
>Fedora virtual machine)
>with the command qemu -m 128  -boot a ...
>I removed the "m" flag -> qemu -boot a ...  and it worked :)
>Hope this helps other users.
>D.
>Domenico Di Leo, PhD student, Università degli Studi di Napoli Federico II
>Ph:     +39 081 676770
>Fax:    +39 081 676574
>Web: http://wpage.unina.it/domenico.dileo (WP)
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-users
