CPP setting in make/compilers/gcc-target-default.cfg has -Wp,$$?
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Mar 7 18:25:38 UTC 2011
Which BSP in the tree is generating this?
Can you send me your Makefile?
The network-demos and examples use these Makefile
fragments. I build these for every BSP at least once
a week.
The Makefile fragments do predate autoconf/make and it
would be nice to switch to that for applications built
after installation. But it hasn't happened.
--joel
On 03/07/2011 12:18 PM, Ralf Corsepius wrote:
> On 03/07/2011 03:04 PM, Peter Dufault wrote:
>> On Mar 7, 2011, at 7:44 , Ralf Corsepius wrote:
>>> gcc-target-default.cfg is junk. Don't use it.
>> It's included by leaf.cfg which is included in the demos, unless I'm very confused.
>> In a network-demo Makefile:
>> include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
>> include $(RTEMS_CUSTOM)
>> include $(PROJECT_ROOT)/make/leaf.cfg
>> In leaf.cfg:
>> # Pull in the desired "target" compiler
>> # Programs built on the host use automake generated rules.
>> # This will not change $(ARCH) -- binaries will still be place as per target
>> include ${CONFIG.CC}
>> Adding an echo to the network-demo Makefile:
>> [dufault at finny12 rtems_main]$ make echo_config_cc
>> CONFIG.CC=/opt/rtems-4.11/make/compilers/gcc-target-default.cfg
> I know ... this stuff is all broken - It's Joel's job to clean this
> stuff up or finally face the truth he deliberately ignores for more than
> a decade: This stuff is unmaintainable and unusable. It should have been
> thrown away long time ago.
> Ralf
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D. Director of Research& Development
