GSOC2011 project RTEMS HyperVisor
张文杰
157724595 at 163.com
Mon Mar 21 14:07:39 UTC 2011
Dear Tobias:
Thanks for your replay, actually i misunderstand the AIR system. And the
work AIR system has done is what i want to implement. My thought is also
to implement a para-virtualisation hypervisor that can run RTEMS and other
OS.(RTEMS as a guest OS). I do not plan to implement a full-virtualisation
hypervisor.
I has some question about AIR:
1). AIR has also implement the ARINC 653 APEX on RTEMS?
2). All the AIR source code is released under GPL?
3). When does AIR source code released? could you send me a copy of source
code foracademic research now?
Wenjie
Best Regards
At 2011-03-21 21:43:52,"Tobias Schoofs" <Tobias.Schoofs at gmx.net> wrote:
>Dear Wenjie,
>your understanding of the AIR system is not 100% correct.
>AIR is a hypervisor that uses para-virtualisation.
>RTEMS is a guest OS for this hypervisor. The guest has to be prepared (para-virtualised) to run on top of the hypervisor. RTEMS is currently our main target, but there may be other OSes as well (e.g. Linux).
>Finally, the AIR hypervisor uses RTEMS *additionally* as hardware abstraction layer (HAL), i.e. the hypervisor itself is based on RTEMS. For this purpose, we have implemented MMU support as well as superuser/user level support in RTEMS.
>The code is under Lesser GPL and will be made available to the RTEMS community.
>From one of your previous e-mails, I got the impression that you plan a hypervisor that does run-time virtualisation. (You mentioned that you do not want to change the guest OS.) I am not sure that you will be able to provide sufficient certification/qualification evidence for such a complex software. At least in areas where ARINC 653 is applied, certification/qualification processes are very demanding. For this reason, available, commercial hypervirsors (VxWorks 653, PikeOS) use para-virtualisation, not full run-time virtualisation.
>Regards,
>Tobias
>-------- Original-Nachricht --------
>> Datum: Mon, 21 Mar 2011 20:31:31 +0800 (CST)
>> Von: "张文杰" <157724595 at 163.com>
>> An: "Metge Jean-Jacques" <Jean-Jacques.Metge at cnes.fr>
>> CC: RTEMS Users <rtems-users at rtems.org>
>> Betreff: RE: GSOC2011 project RTEMS HyperVisor
>> AIR/AIR IIseems that it hasimplemented ARINC 653 interface in RTEMS, but i
>> do
>> not know if these implements is opened. If it is opened we also modify
>> their work,
>> Because ARINC 653 interface should be based on Hypervisor architecture
>> whereas
>> AIR implement is based on native RTEMS. XtratuM is a independent
>> Hypervisor which
>> has nothing to do with other OS, but my thought is to add a Hypervisor to
>> RTEMS. Just
>> reference the implement of XtratuM
>> At 2011-03-21 16:21:12,"Metge Jean-Jacques" <Jean-Jacques.Metge at cnes.fr>
>> wrote:
>> Hi,
>> For my information, what do you exactly intend to do in the frame of this
>> GSOC, that would not have been already done, either in the frame of AIR/AIR
>> II or in the frame of XtratuM ?
>> Best regards
>> Jean-Jacques METGE
>> French Space Agency
>> De :rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]De
>> la part de ???
>> Envoyé : dimanche 20 mars 2011 14:57
>> À : 张文杰
>> Cc : RTEMS Users
>> Objet : Re:GSOC2011 project RTEMS HyperVisor
>> Sorry for forgetting add the reference link.
>> [1]. http://www.rtems.com/wiki/index.php/RTEMSHyperVisor
>> [2]. http://air.di.fc.ul.pt/air/?Home
>> [3].http://www.xtratum.org/
>> [4]. http://www.helenos.org/
>> At 2011-03-20 21:50:39,"张文杰" <157724595 at 163.com> wrote:
>> Hi, all:
>> I am a student who is preparing for participating the GSOC2011 RTEMS. My
>> interested project isRTEMS HyperVisor [1]. This
>> project ‘s ultimate goal is to make RTEMS support to run multiple
>> operating systems(like Linux or uclinux) and meantime RTEMS can be
>> adapted to fullfill the requirements defined in the ARINC 653 standard. So
>> the project is divided into two milestone tasks: 1) add a HyperVisor to
>> RTEMS. the design of HyperVisor is compatible with ARINC 653 standard. 2).
>> implement ARINC 653 interface in
>> RTEMS which can reference the a ESA project named AIR[2].
>> Hypervisor, also called virtual machine monitor (VMM), is one of
>> virtualization techniqueswhich allow multiple operating systems.
>> For embedded systems it must have real-time capability. And there is also
>> a challenge to the resource-constrained embedded
>> systems, becausesupport for virtualization requiresmemory protection (in
>> the form of a memory management unit or at least a
>> memory protection unit) and a distinction between user mode and privileged
>> mode, which rules out many microcontrollers. About the implement of
>> HyperVisor for RTEMS there are two projects we can reference. First is project
>> XtratuM [3] which is a small
>> native (bare-metal) hypervisor, now the RTEMS has been ported to XtratuM
>> run as a guest OS and its design use ARINC 653 as
>> a reference although ARINC-653 is not directly applicable to the
>> hypervisor systems. Another project is HelenOS operating
>> system [4] which is designed as a relatively small microkernel assisted
>> with a set of userspace drivers and server tasks, Its kernel
>> is a good reference candidate for the design of Hypervisor.
>> This is just my initial thoughts, if there is any inappropriate please
>> point out.Do not hesitate to add your comments.
>> Wenjie Zhang
>> Best Regards
>GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
>gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
URL: <http://lists.rtems.org/pipermail/users/attachments/20110321/9ea1ad0f/attachment-0001.html>
