RES: Create one pen drive to boot an example program hello.exe
Wendell Pereira da Silva
wendell.silva at compsisnet.com.br
Mon May 9 17:49:57 UTC 2011
Bruno,
Since you're using COM1 as a console (9600-8N1), what kind of terminal emulation software are you using?
In this case, you should use a program like realterm, connected at the COM port, using the same configuration (9600-8N1), to see your program's output.
Assuming that you're using VirtalBox to boot a pendrive, it looks like the diagram attached.
I hope this helps you.
Regards,
Wendell.
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de BRUNO FELIPE
Enviada em: segunda-feira, 9 de maio de 2011 13:43
Para: rtems-users at rtems.org
Assunto: Re: Create one pen drive to boot an example program hello.exe
Dear,
I used suggestions from Joel and Till. but without any result favorable to my goal. The problem that I found and still have is that I can not display the output of any program on your computer's startup, using the pen drive. I can see the menu options and choose the programs, but can not show the result of the programs.
In the GNU GRUB menu, I have two programs:
hello pc386
minimum pc386
By choosing the option "hello pc386" I have the following output:
Initializing console on COM1 port 9600-8N-1
Warning: This Will Be the last message on console
How do I show the output of the hello program, after selecting the menu?
Thank you for all.
Best regards,
Bruno
2011/5/6 BRUNO FELIPE <brunogpf at gmail.com<mailto:brunogpf at gmail.com>>
Dear,
I'm currently working with Fedora 14 - 11 RTEMS on VirtualBox. I need to create one pen drive to boot an example program (hello.exe).
I describe following the steps that I make. First, I use qemu to emulate de process, along with "RTEMS-boot.img"and the file "RTEMS-grub.cfg" modified for the program hello.exe. Finally, I try to execute the program hello.exe in the qemu but in the console output not appear anything (I make the compilation with pc386 script).
How can create a .exe file that redirects the stdout to console? Or simple compile the herlo world example with this feature?
Do you have any sugestion, to this problem ?
Thank you for all.
Best regards,
Bruno
URL: <http://lists.rtems.org/pipermail/users/attachments/20110509/b12fea15/attachment.html>
Type: image/png
Desc: host-guest.png
URL: <http://lists.rtems.org/pipermail/users/attachments/20110509/b12fea15/attachment.png>
