Create one pen drive to boot an example program hello.exe
Gedare Bloom gedare at gwmail.gwu.edu
Mon May 9 17:56:15 UTC 2011
When using QEMU, you have to connect a virtual terminal to see the
output, e.g. with a VNC client and QEMU has some default port to
connect. Alternately, you can configure RTEMS with
USE_COM1_AS_CONSOLE=1 and run qemu from the command line and have the
RTEMS executable output show up in qemu's console window.
On Mon, May 9, 2011 at 1:49 PM, Wendell Pereira da Silva
<wendell.silva at compsisnet.com.br> wrote:
> Bruno,
> Since you’re using COM1 as a console (9600-8N1), what kind of terminal
> emulation software are you using?
> In this case, you should use a program like realterm, connected at the COM
> port, using the same configuration (9600-8N1), to see your program’s output.
> Assuming that you’re using VirtalBox to boot a pendrive, it looks like the
> diagram attached.
> I hope this helps you.
> Regards,
> Wendell.
> De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em
> nome de BRUNO FELIPE
> Enviada em: segunda-feira, 9 de maio de 2011 13:43
> Para: rtems-users at rtems.org
> Assunto: Re: Create one pen drive to boot an example program hello.exe
> Dear,
> I used suggestions from Joel and Till. but without any result favorable to
> my goal. The problem that I found and still have is that I can not display
> the output of any program on your computer's startup, using the pen drive. I
> can see the menu options and choose the programs, but can not show the
> result of the programs.
> In the GNU GRUB menu, I have two programs:
> hello pc386
> minimum pc386
> By choosing the option "hello pc386" I have the following output:
> Initializing console on COM1 port 9600-8N-1
> Warning: This Will Be the last message on console
> How do I show the output of the hello program, after selecting the menu?
> Thank you for all.
> Best regards,
> Bruno
> 2011/5/6 BRUNO FELIPE <brunogpf at gmail.com>
> Dear,
> I'm currently working with Fedora 14 - 11 RTEMS on VirtualBox. I need to
> create one pen drive to boot an example program (hello.exe).
> I describe following the steps that I make. First, I use qemu to emulate de
> process, along with "RTEMS-boot.img"and the file "RTEMS-grub.cfg" modified
> for the program hello.exe. Finally, I try to execute the program hello.exe
> in the qemu but  in the  console output not appear anything (I make the
> compilation with pc386 script).
> How can create a .exe file that redirects the stdout to console? Or simple
> compile the herlo world example with this feature?
> Do you have any sugestion, to this problem ?
> Thank you for all.
> Best regards,
> Bruno
> rtems-users mailing list
