cleaner & greener (was Re: A patch for RTEMS4.10.0 PowerPC heap space initialization)
Peter Dufault dufault at hda.com
Thu May 12 10:11:50 UTC 2011
On May 11, 2011, at 8:35 , Kate Feng wrote:
>> Eighty column limits and no tabs.
> Not sure what you meant here.
Eighty character limit on the length of a code line, and tabs should be expanded to spaces.
In my own code I've broken away from the limits of what will fit on a punch card and gone to 110 columns.  I also no longer keep sequence numbers in the last 8 columns.
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
