cleaner & greener (was Re: A patch for RTEMS4.10.0 PowerPC heap space initialization)
Kate Feng
feng1 at bnl.gov
Fri May 13 15:08:53 UTC 2011
Sebastian Huber wrote:
> On 05/13/2011 04:13 PM, Kate Feng wrote:
>> +++ rtems-4.10.0/c/src/lib/libbsp/shared/bootcard.c 2011-05-13 09:53:27.000000000 -0400
>> @@ -53,6 +53,7 @@
>> #include <bsp/bootcard.h>
>> #include <rtems/bspIo.h>
>> +#include <rtems/malloc.h>
>> * At most a single pointer to the cmdline for those target
>> @@ -65,6 +66,9 @@
>> extern bool rtems_unified_work_area;
>> +static uintptr_t heap_sbrk_spared=0;
>> +extern uintptr_t _bsp_sbrk_init(uintptr_t, uintptr_t*);
> The _bsp_sbrk_init() function is only available on PowerPC.
Thanks for your feedback. How about the attached ?
I added _bsp_sbrk_init() for other BSPs at
c/src/lib/libbsp/shared/sbrk.c. According to Joel, it would be needed
in the future. The name seems to be OK at this level, unless Joel comes
up with a different name. One could fill in the function when the memory
protection is implemented. It seems that other
non-PPC BSPs all use the sbrk() from c/src/lib/libbsp/shared/sbrk.c.
More comments before PR ?
Thanks,
Kate
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20110513/b9d583d1/attachment.bin>
