cleaner & greener (was Re: A patch for RTEMS4.10.0 PowerPC heap space initialization)
Kate Feng
feng1 at bnl.gov
Fri May 13 17:41:10 UTC 2011
I agree so. More comments regarding the attached patch before the
PR ?
Thanks,
Kate
Gedare Bloom wrote:
> +static uintptr_t heap_sbrk_spared=0;
> Why is this declared as static global? It looks to me like it is only
> used in one function, can it go on that function's local variables?
> _bsp_sbrk_init()
> Should be renamed as bsp_sbrk_init() to be consistent with other bsp functions.
> On Fri, May 13, 2011 at 11:08 AM, Kate Feng <feng1 at bnl.gov> wrote:
>> Sebastian Huber wrote:
>>> On 05/13/2011 04:13 PM, Kate Feng wrote:
>>>> +++ rtems-4.10.0/c/src/lib/libbsp/shared/bootcard.c 2011-05-13
>>>> 09:53:27.000000000 -0400
>>>> @@ -53,6 +53,7 @@
>>>> #include <bsp/bootcard.h>
>>>> #include <rtems/bspIo.h>
>>>> +#include <rtems/malloc.h>
>>>> * At most a single pointer to the cmdline for those target
>>>> @@ -65,6 +66,9 @@
>>>> extern bool rtems_unified_work_area;
>>>> +extern uintptr_t _bsp_sbrk_init(uintptr_t, uintptr_t*);
>>> The _bsp_sbrk_init() function is only available on PowerPC.
>> Thanks for your feedback. How about the attached ?
>> I added _bsp_sbrk_init() for other BSPs at
>> c/src/lib/libbsp/shared/sbrk.c. According to Joel, it would be needed
>> in the future. The name seems to be OK at this level, unless Joel comes
>> up with a different name. One could fill in the function when the memory
>> protection is implemented. It seems that other
>> non-PPC BSPs all use the sbrk() from c/src/lib/libbsp/shared/sbrk.c.
>> More comments before PR ?
>> Thanks,
>> Kate
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20110513/eae5d944/attachment.bin>
