cleaner & greener (was Re: A patch for RTEMS4.10.0 PowerPC heap space initialization)
Kate Feng feng1 at bnl.gov
Wed May 18 13:57:38 UTC 2011
Till Straumann wrote:
> On 05/17/2011 01:20 PM, Till Straumann wrote:
>> On 05/16/2011 11:59 PM, Chris Johns wrote:
>>> On 17/05/11 5:27 AM, Kate Feng wrote:
>>>> The PR is at http://rtems.org/bugzilla/show_bug.cgi?id=1797
>>>> Thanks for all the feedback. I am glad that the API is more or
>>>> less verified. Previously, I could not decide where to place the
>>>> macro.
>>>> #define CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
>>>> The patch for the mvme5500 BSP is updated as well at
>>>> http://www.rtems.org/bugzilla/show_bug.cgi?id=1786
>>> Thanks for sorting this. I will leave the patches for Till to review
>>> and
>>> commit.
>> OK, will do.
> As a matter of fact, I'm thinking of adding
> to the bspopts.h of the BSPs that currently use
> powerpc/shared/startup/sbrk.c
> That way, the entire feature may be configured away
> by the user if they want.
I was thinking to use a common header as well.  I assume the
configuration you meant
would only touch the bspopts.h of the BSPs that currently use
powerpc/shared/startup/sbrk.c.
As long as it does not affect the bspopts.h of the other BSPs, that
would be fine.
If Joel agrees, it would be good to move
uintptr_t bsp_sbrk_init(uintptr_t, uintptr_t*);
from bootcard.c to bspopts.h as well.
Is it easy to do that without me updating the patch so that there is no
broken ring ?
Kate
> T.
>> Note that there will be a slight asymmetry if you configure a unified
>> work area and have sbrk support. While allocating from the unified heap
>> via 'malloc()' then the heap is transparently extended via sbrk().
>> However, the unified heap is *not* extended transparently when you
>> allocate via _Workspace_Allocate() / rtems_workspace_allocate().
>> Given that the entire sbrk business is only required for special
>> purposes I assume we can live with that asymmetry for now (and
>> the unified heap can always be extended explicitly via 'sbrk'
>> and _Heap_Extend()).
>> - Till
>>> I have finished PR1774 so this is all that needs to be applied to start
>>> the 4.10.1 release process.
>>> Chris
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
