rename() function
Wed May 18 20:19:51 UTC 2011
It is supposed to work. Can you post a complete test case?
--joel
"Robert S. Grimes" <rsg at alum.mit.edu> wrote:
>Does the rename() function really work for the IMFS?  I am using 4.9/4.10 on sparc, and the following code crashes my app immediately on entry into the rename() function:
>   printf("About to call\n");
>   rename("hello.txt", "goodby.txt");
>   printf("rename done\n");
>The first printf() works, then the system crashes.  And yes, the source file exists, and the destination does not.
