arm multilib not building on head
Joel Sherrill
joel.sherrill at OARcorp.com
Tue May 24 19:31:02 UTC 2011
Hi,
Can anyone build the arm-rtems4.11 target on
the CVS head using multilib? I used this configure
command:
../rtems/configure --target=arm-rtems4.11
--prefix=/home/joel/rtems-4.11-work/bsp-install/
--disable-multiprocessing --disable-smp --enable-cxx --disable-rdbg
--enable-maintainer-mode --enable-tests=samples --enable-networking
--enable-shttpd --enable-posix --disable-itron --disable-deprecated
--disable-ada --disable-expada --enable-multilib
I don't have time to investigate if this is
just me or a general breakage.
Joel Sherrill, Ph.D. Director of Research& Development
