arm multilib not building on head
Ralf Corsepius ralf.corsepius at rtems.org
Wed May 25 11:39:40 UTC 2011
On 05/24/2011 09:31 PM, Joel Sherrill wrote:
> Hi,
> Can anyone build the arm-rtems4.11 target on
> the CVS head using multilib?
Yes - Without major problems.
> I used this configure
> command:
> ../rtems/configure --target=arm-rtems4.11
> --prefix=/home/joel/rtems-4.11-work/bsp-install/
> --disable-multiprocessing --disable-smp --enable-cxx --disable-rdbg
> --enable-maintainer-mode --enable-tests=samples --enable-networking
> --enable-shttpd --enable-posix --disable-itron --disable-deprecated
> --disable-ada --disable-expada --enable-multilib
... tons of unused options ...
> I don't have time to investigate if this is
> just me or a general breakage.
You are not providing sufficinet information about what fails to be able
to help.
Ralf
