Target Device
Cláudio Silva claudiodcsilva at gmail.com
Fri May 27 14:08:41 UTC 2011
Hi,
You can boot from the same hard drive, no need for another (only if
you want hard drive access?).
If you have GRUB installed in your PC, you just need to add one line
to the grub configuration:
set root=(hd1,1)
multiboot (hd1,1)/path_to_your_exe/test.exe
As explained in http://www.rtems.com/wiki/index.php/QEMU
Some grub versions also support this (i think... i haven't used grub
for booting rtems in a while...):
kernel=(hd1,1)/path_to_your_exe/test.exe
If you don't have grub installed you can use the grub.img:
http://www.rtems.org/ftp/pub/rtems/qemu/i386-pc/rtems-boot.img
Instructions for this are also on the QEMU wiki page.
There is also the possiblity to use etherboot. You just need to adapt
the instructions for Virtual Box
(http://www.rtems.com/wiki/index.php/RTEMS_on_Virtualbox) to your PC.
For developing purposes i highly recommend using a simulator like QEMU.
Regards,
Cláudio Silva
MSc in Aerospace Engineering
Instituto Superior Técnico
Portugal
On Fri, May 27, 2011 at 2:48 PM, Eduardo LR-Informática
<eduardo.bortolini at lri.com.br> wrote:
> Dear Cláudio,
> thank you very much for your help. Actually I am not planning to install in
> virtual machine or in my PC. I was thinking in put in another hard drive. I
> found this link: http://www.rtems.com/wiki/index.php/Bochs, seems what I
> need, I am planning to put the image (I am not sure in how to generate the
> image) in another hard drive and boot.... Do you have some reference
> explaning how to do it?
> Thanks,
> Eduardo
> Hello,
> Assuming that you have built and installed RTEMS correctly you can
> follow the instructions on the Getting Started Guide:
> http://rtems.org/onlinedocs/doc-current/share/rtems/html/started/started00062.html
> You can build the sample applications available in the CVS. For that
> you must checkout "examples-v2" from the RTEMS CVS:
> cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS login
> cvs -d :pserver:anoncvs at www.rtems.com:/usr1/CVS -z 9 co -P examples-v2
> Also you must export the  RTEMS_MAKEFILE_PATH variable on your
> environment. Assuming that you did not change the path were you
> installed RTEMS:
> export RTEMS_MAKEFILE_PATH=/opt/rtems-4.10/i386-rtems4.10/pc386/ (or
> any other BSP you have installed: e.g. pc586)
> Then you just have to change directory to examples-v2 and issue make.
> The several examples should build and produce executables. Finally you
> can run those .exe using qemu[1], virtualbox[2] or even your own PC:
> [1] http://wiki.rtems.org/wiki/index.php/QEMU
> [2] http://wiki.rtems.org/wiki/index.php/RTEMS_on_Virtualbox
> Cláudio Silva
> 2011/5/26 Eduardo LR-Informática <eduardo.bortolini at lri.com.br>:
>> Hi all,
>> I am trying to put RTEMS (4.10.0) system in a X86 architeture. To make it
>> I
>> installed Fedora (2.6.38.6-26.rc1.fc15.i686) and I followed the
>> instructions
>> in theses links:
>> http://rtems.org/wiki/index.php/APT/Yum_Repository
>> http://www.rtems.org/wiki/index.php/Quick_Start
>> I compiled the code and give make and make install resulting in these
>> files/folders:
>> config.log
>> config.status
>> i386-rtems4.10
>> make
>> Makefile
>> testsuites
>> tools
>> At this point I don't know how to proceed, my intention is to put the
>> system
>> in another machine (x86 architeture) to make a embedded system. Reading
>> the
>> documents I didn't find or understand what is the next step... if somebody
>> could help me I would appreciate....
>> Best Regards,
>> Eduardo Bortolini
>> Engenharia de Aplicação
>> LR Informática Industrial - MATRIZ
>> Rua Sergio Jungblut Dietrich, 900 pav. 26
>> CEP: 91060-410 - Porto Alegre - RS - Brasil
>> ( 0800 704-4788
>> 2 +55-51-2129-3008
>> )+55 51 2129-3023
>> 8 http://www.lri.com.br/
>> * eduardo at lri.com.br
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
