Отв.: Отв.: r+b filemode
Fri May 27 23:23:56 UTC 2011
Returning us to the list.
On 27/05/11 7:33 PM, Oleg Moroz wrote:
> i'm using rfs.
Thanks.
Which version of RTEMS are you using ?
> *От:* Chris Johns <chrisj at rtems.org>
> *Кому:* Oleg Moroz <oleg_moroz at yahoo.com>
> *Копия:* Joel Sherrill <joel.sherrill at oarcorp.com>;
> "rtems-users at rtems.org" <rtems-users at rtems.org>
> *Отправлено:* пятница, 27 май 2011 11:38
> *Тема:* Re: Отв.: r+b filemode
> On 27/05/11 3:00 PM, Oleg Moroz wrote:
>  > *От:* Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>>
> <mailto:oleg_moroz at yahoo.com>>; "rtems-users at rtems.org
> <mailto:rtems-users at rtems.org>"
>  > <rtems-users at rtems.org <mailto:rtems-users at rtems.org>>
>  > *Отправлено:* четверг, 26 май 2011 21:57
>  > *Тема:* Re: r+b filemode
>  > Which filesystem?
>  > Do you have a complete small test case?
>  > Someone else will likely have other ideas. I am on travel and just
>  > wanted to ask the obviuous questions.
>  > --joel
>  > Oleg Moroz <oleg_moroz at yahoo.com <mailto:oleg_moroz at yahoo.com>
> <mailto:oleg_moroz at yahoo.com <mailto:oleg_moroz at yahoo.com>>> wrote:
>  > >Hello everyone, i have a trouble with opening file. i have opened the
>  > file with "wb" mode. Write to it 512 bytes. close it. after this open it
>  > with "r+b" mode. then trying:
>  > >fseek(file,0,SEEK_END);
>  > >int i = ftell(file);
>  > >after this i=0
>  > >but when i'm opening file with "rb" mode - i=512. how i can use "r+b"
>  > mode?
>  > int create_ring_buffer_file(char *filename)
>  > FILE* outfile=fopen(filename,"wb");
>  > if (outfile==NULL) return -1;
>  > char *block=(char *)malloc(512);
>  > memset(block,0,512);
>  > fwrite(block,512,1,outfile);
>  > free(block);
>  > fclose(outfile);
>  > outfile=fopen(filename,"r+b");
>  > fseek(outfile,0,2);
>  > int i = ftell(outfile); //i=0
>  > fclose(outfile);
>  > outfile=fopen(filename,"rb");
>  > fseek(outfile,0,2);
>  > int i = ftell(outfile); //i=512
>  > fclose(outfile);
>  > return 0;
> Which file system are you using ?
> Chris
