Create one pen drive to boot an example program hello.exe
Joel Sherrill
joel.sherrill at OARcorp.com
Mon May 9 18:33:02 UTC 2011
On 05/09/2011 11:43 AM, BRUNO FELIPE wrote:
> Dear,
> I used suggestions from Joel and Till. but without any result
> favorable to my goal. The problem that I found and still have is that
> I can not display the output of any program on your computer's
> startup, using the pen drive. I can see the menu options and choose
> the programs, but can not show the result of the programs.
> In the GNU GRUB menu, I have two programs:
> hello pc386
> minimum pc386
> By choosing the option "hello pc386" I have the following output:
> Initializing console on COM1 port 9600-8N-1
> Warning: This Will Be the last message on console
> How do I show the output of the hello program, after selecting the menu?
> Thank you for all.
> Best regards,
> Bruno
> 2011/5/6 BRUNO FELIPE <brunogpf at gmail.com <mailto:brunogpf at gmail.com>>
> Dear,
> I'm currently working with Fedora 14 - 11 RTEMS on VirtualBox. I
> need to create one pen drive to boot an example program (hello.exe).
> I describe following the steps that I make. First, I use qemu to
> emulate de process, along with "RTEMS-boot.img"and the file
> "RTEMS-grub.cfg" modified for the program hello.exe. Finally, I
> try to execute the program hello.exe in the qemu but in the
> console output not appear anything (I make the compilation with
> pc386 script).
> How can create a .exe file that redirects the stdout to console?
> Or simple compile the herlo world example with this feature?
It is doing it. You just didn't invoke qemu correctly.
> Do you have any sugestion, to this problem ?
usr/bin/qemu -M pc -m 64 -cpu core2duo -boot a -fda
/home/joel/qemu/pc386_fda -hda fat:/home/joel/qemu/hd --no-reboot
-serial stdio
The important option there is "-serial stdio"
Qemu has a lot of options. There is plenty of information on
qemu in its manual, the RTEMS Wiki and the RTEMS mailing
list archives.
> Thank you for all.
> Best regards,
> Bruno
Joel Sherrill, Ph.D. Director of Research& Development
