cleaner & greener (was Re: A patch for RTEMS4.10.0 PowerPC heap space initialization)
Peter Dufault
dufault at hda.com
Thu May 12 11:10:47 UTC 2011
On May 12, 2011, at 6:10 , Sebastian Huber wrote:
> No, uintptr_t is the type used by the heap code. We work here with addresses
> and not sizes of single objects.
I had to look up the definition of uintptr_t. At least according to Wikipedia it's C99 and is defined as:
Integers wide enough to hold pointers
intptr_t and uintptr_t is a signed and unsigned integer which are guaranteed to hold the value of a pointer. These two types are optional.
"The limits of these types are defined with the following macros:
• INTPTR_MIN is the minimum value (−32,767 [−215 + 1] or less) of intptr_t.
• INTPTR_MAX is the maximum value (32,767 [215 − 1] or greater) of intptr_t.
• UINTPTR_MAX is the maximum value (65,535 [216 − 1] or greater) of uintptr_t.
Here's the function:
void
bsp_get_work_area(
void **work_area_begin,
uintptr_t *work_area_size,
void **heap_begin,
uintptr_t *heap_size,
uintptr_t *sbrk_amount);
Without looking at the code it appears that "work_area_begin" is referring to an address, but that's pointing to a "void *" and not a "uintptr_t". "work_area_size" sure sounds as if it is returning a size and not an address.
I don't see much benefit of uintptr_t over void * at the moment, I'll have to try to think of one. I'd expect the signature to be:
void
bsp_get_work_area(
size_t *work_area_size,
void **heap_begin,
size_t *heap_size,
size_t *sbrk_amount);
Or, to provide abstraction without stepping on the "_t" restricted name space,
void
bsp_get_work_area(
address_type *work_area_begin,
address_size_type *work_area_size,
address_type *heap_begin,
address_size_type *heap_size,
address_size_type *sbrk_amount);
However:
1. When would address_type not be void *?
2. When would address_size_type not be size_t?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
