cleaner & greener (was Re: A patch for RTEMS4.10.0 PowerPC heap space initialization)
Till Straumann
strauman at slac.stanford.edu
Tue May 17 18:58:15 UTC 2011
On 05/17/2011 01:20 PM, Till Straumann wrote:
> On 05/16/2011 11:59 PM, Chris Johns wrote:
>> On 17/05/11 5:27 AM, Kate Feng wrote:
>>> The PR is at http://rtems.org/bugzilla/show_bug.cgi?id=1797
>>> Thanks for all the feedback. I am glad that the API is more or
>>> less verified. Previously, I could not decide where to place the macro.
>>> #define CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
>>> The patch for the mvme5500 BSP is updated as well at
>>> http://www.rtems.org/bugzilla/show_bug.cgi?id=1786
>> Thanks for sorting this. I will leave the patches for Till to review and
>> commit.
> OK, will do.
As a matter of fact, I'm thinking of adding
to the bspopts.h of the BSPs that currently use
powerpc/shared/startup/sbrk.c
That way, the entire feature may be configured away
by the user if they want.
T.
> Note that there will be a slight asymmetry if you configure a unified
> work area and have sbrk support. While allocating from the unified heap
> via 'malloc()' then the heap is transparently extended via sbrk().
> However, the unified heap is *not* extended transparently when you
> allocate via _Workspace_Allocate() / rtems_workspace_allocate().
> Given that the entire sbrk business is only required for special
> purposes I assume we can live with that asymmetry for now (and
> the unified heap can always be extended explicitly via 'sbrk'
> and _Heap_Extend()).
> - Till
>> I have finished PR1774 so this is all that needs to be applied to start
>> the 4.10.1 release process.
>> Chris
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
