Cannot get Dynamic IP address
Eric Norum
wenorum at lbl.gov
Tue May 17 22:12:07 UTC 2011
There's not enough information here to really determine the problem.
What do your application's network configuration structure initializers look like? Are you sure that you've set them up to use DHCP to set the address dynamically?
On May 17, 2011, at 10:21 AM, João Rasta wrote:
> Hi,
> I have used rtems_bsdnet_initialize_network() to initialize the networking stack with success in an ad-hoc connection. However now i'm connecting the RTEMS system to a router, from where it should get a dynamic IP. However, when I do:
> rtems_bsdnet_initialize_network ();
> rtems_bsdnet_show_inet_routes();
> rtems_bsdnet_show_if_stats();
> The stats allways show it recognizes the same gateway IP and allways attributes the same fixed IP:
> greth: driver attached
> **** PHY ****
> Vendor: 5043 Device: c Revision: 2
> Current Operating Mode: 100 Mbit Full Duplex
> Autonegotiation Time: 1668ms
> Destination Gateway/Mask/Hw Flags Refs Use Expire Interface
> default 192.168.0.1 UGS 0 0 0 gr_eth1
> 192.168.0.0 255.255.255.0 U 0 0 4 gr_eth1
> 192.168.0.1 UHL 1 0 4 gr_eth1
> ************ INTERFACE STATISTICS ************
> ***** gr_eth1 *****
> Ethernet Address: 00:80:7F:22:61:79
> Address:192.168.0.67 Broadcast Address:192.168.0.255 Net mask:255.255.255.0
> Flags: Up Broadcast Running Simplex
> Send queue limit:50 length:0 Dropped:0
> Rx Interrupts:0 Rx Packets:0 Length:0 Non-octet:0
> Bad CRC:0 Overrun:0 Tx Interrupts:0 Maximal Frags:1
> After the Autonegotiation i would expect it to return an IP such as 10.101.etc. Also the gateway should be 10.101.etc. What am I missing?
> Best,
> JM _______________________________________________
> rtems-users mailing list
> rtems-users at rtems.org
Eric Norum
wenorum at lbl.gov
