Aliasing problem in ip_input.c with GCC 4.6 on PowerPC?
Sebastian Huber
Fri May 27 16:48:43 UTC 2011
On 25/05/11 17:14, Till Straumann wrote:
> Is it our old friend in_cksum_hdr() ?
Was this the old friend that doesn't work with optimization disabled?
The problem I encountered appears if I use the -fstrict-aliasing
optimization (enabled with -O2). The mbufs get corrupted in
ip_input(). Here is a sample difference between the assembler code
generated with -fstrict-aliasing and with -fno-strict-aliasing:
+.LBB50:
.loc 1 839 0
lwz 11,16(9) # <variable>.ipf_prev, <variable>.ipf_prev
stw 31,12(11) # <variable>.ipf_next, p
.loc 1 840 0
- lwz 11,12(9) # <variable>.ipf_next, <variable>.ipf_next
- lwz 0,16(9) # <variable>.ipf_prev, <variable>.ipf_prev
- stw 0,16(11) # <variable>.ipf_prev, <variable>.ipf_prev
+ lwz 9,12(9) # <variable>.ipf_next, <variable>.ipf_next
+.LVL34:
+ stw 11,16(9) # <variable>.ipf_prev, <variable>.ipf_prev
+.LBE50:
> Till
> On 05/25/2011 06:28 AM, Sebastian Huber wrote:
>> Hello,
>> experienced someone network problems with GCC 4.6 on PowerPC? I have
>> a test
>> application that works fine with ip_input.c compiled with "-O2
>> -fno-strict-aliasing" and fails with "-O2 -fstrict-aliasing".
>> Unfortunately
>> the difference between the two generated assembler files is quite
>> huge. The
>> option -Wstrict-aliasing=1 yields no warnings.
>> Have a nice day!
> rtems-users mailing list
> rtems-users at rtems.org
