MVME162 BSP Issues
Hoover, Victor P CTR NAVAIR, AIR 4.1.3.3
victor.hoover.ctr at navy.mil
Thu Nov 3 16:35:53 UTC 2011
> -----Original Message-----
> From: Eric Norum [mailto:wenorum at lbl.gov]
> Sent: Wednesday, November 02, 2011 18:33
> To: Hoover, Victor P CTR NAVAIR, AIR 4.1.3.3
> Cc: rtems-users at rtems.org
> Subject: Re: MVME162 BSP Issues
> Stack overflow perhaps?
> Using a C library routine before all the required data structures have
> been set up?
> Have you tried using printk in your startup tests?
Just to clarify, I'm testing with the testsuites/samples/fileio program.
The problems are occurring in the function that displays the menu to the
user. I'm assuming that at this point everything should be initialized.
Stack size:
I've increased the stack sizes and still have the same problems. Besides,
stack issues wouldn't explain the following:
printf("test output\n"); // works fine
printf("test output"); // locks the processor
printk:
I tried using printk to display a newline terminated text string. No output
Appeared on the console port but the system didn't hang.
I did find out why the 162 BSP doesn't accept any user input though. The
char_ready function in console.c always returns false even on success. Once
I changed the final line in the function to return true then I managed to
get input data to the program.
That's one step further than I was yesterday.
- Vic Hoover
Type: application/x-pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20111103/024567ac/attachment.bin>
