MVME162 BSP Issues
Hoover, Victor P CTR NAVAIR, AIR 4.1.3.3
victor.hoover.ctr at navy.mil
Fri Nov 4 16:37:06 UTC 2011
> -----Original Message-----
> From: Chris Johns [mailto:chrisj at rtems.org]
> Sent: Thursday, November 03, 2011 18:46
> To: Hoover, Victor P CTR NAVAIR, AIR 4.1.3.3
> Cc: rtems-users at rtems.org
> Subject: Re: MVME162 BSP Issues
> Are you linking with the correct libc ? If you have the LC part you do
> not have an FPU. If your linker command or tools are not correct the
> default 68020 library links and that requires a FPU. This always trips
> in the printf function first.
> A simple check is:
> m68k-rtems4.11-objdump -d myapp | grep fmovemx
> Chris
Ahhh ... yeah. That would be the problem; thanks.
I was starting to suspect something along those lines when I notice that ticker
was working right but fileio wasn't and the only obvious difference was that
fileio starts it's tasks with the FPU flag set.
Time to try again...
- Vic Hoover
Type: application/x-pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20111104/260044b0/attachment.bin>
