_Chain_Is_first/last overshoot
Sébastien Bourdeauducq
sebastien at milkymist.org
Wed Nov 9 19:56:19 UTC 2011
-------- Original Message --------
Subject: [Milkymist-devel] [PATCH, tentative] RTEMS:
Date: Wed, 9 Nov 2011 16:53:53 -0300
From: Werner Almesberger <werner at almesberger.net>
Reply-To: Milkymist One, Milkymist SoC and Flickernoise developers' list
<devel at lists.milkymist.org>
Doubly-linked lists ("chains") in RTEMS have a "control" block that
looks like the next/prev link pair in an element. The list elements
link both ways to this control block.
_Chain_Is_first and _Chain_Is_last only probed if the link to the
next element - which would be the control block - is non-NULL.
Telling by the function description and given that there are already
functions called _Chain_Is_head and _Chain_Is_tail (which could be
simplified), this is probably not the intended behaviour.
This also affects the aliases rtems_chain_is_first and
rtems_chain_is_last.
These functions are not used a lot and I haven't seen any immediate
effect on M1 after changing them, so I can't say whether this patch
may unearth other problems.
- Werner
Index: cpukit/score/inline/rtems/score/chain.inl
RCS file: /usr1/CVS/rtems/cpukit/score/inline/rtems/score/chain.inl,v
retrieving revision 1.23
diff -U 4 -r1.23 chain.inl
--- cpukit/score/inline/rtems/score/chain.inl 25 Nov 2010 11:48:11
-0000 1.23
+++ cpukit/score/inline/rtems/score/chain.inl 9 Nov 2011 19:42:13 -0000
@@ -296,9 +296,9 @@
RTEMS_INLINE_ROUTINE bool _Chain_Is_first(
const Chain_Node *the_node
- return (the_node->previous == NULL);
+ return the_node->previous->previous == NULL;
/** @brief Is this the Last Node on the Chain
@@ -313,9 +313,9 @@
RTEMS_INLINE_ROUTINE bool _Chain_Is_last(
- return (the_node->next == NULL);
+ return the_node->next->next == NULL;
/** @brief Does this Chain have only One Node
http://lists.milkymist.org/listinfo.cgi/devel-milkymist.org
IRC: #milkymist at Freenode
