rtems_message_queue_send from ISR?
Thu Nov 10 12:34:39 UTC 2011
File a PR. I have never heard of this before. It will have to be looked at.
--joel
Sébastien Bourdeauducq <sebastien at milkymist.org> wrote:
>Hi,
>is it really OK to use rtems_message_queue_send() from an ISR, as
>http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/c_user/c_user00114.html
>suggests?
>See the message below... and
>http://lists.milkymist.org/pipermail/devel-milkymist.org/2011-November/002100.html
>for the previous e-mail.
>Does the BSP/CPU code have anything to do to ensure that this race
>condition doesn't occur?
>Sébastien
>-------- Original Message --------
>Subject: Re: [Milkymist-devel] [PATCH, tentative] RTEMS: don't rely on
>number_of_pending_messages in _CORE_message_queue_Submit
>Date: Wed, 9 Nov 2011 21:27:16 -0300
>From: Werner Almesberger <werner at almesberger.net>
>Reply-To: Milkymist One, Milkymist SoC and Flickernoise developers' list
><devel at lists.milkymist.org>
>Hmm, maybe I should rephrase the problem description so that it
>becomes a bit clearer. There's also an enqueue-enqueue race I
>hadn't mentioned. Here's the improved version:
>If it's permissible to call rtems_message_queue_send from an
>interrupt, then there is at least one race condition in the core
>message subsystem.
>This created the MIDI/mouse hang we love so much on M1.
>The problem is as follows: RTEMS queues use pre-allocated message
>buffers that are kept on an "inactive" (free) list. When enqueuing
>a message, a buffer is first removed from the inactive list, data
>it copied to it, and it is then added to the pending list.
>The reverse happens when dequeuing. Besides these two queues, there
>is also a counter called number_of_pending_messages keeping track,
>as the name suggests, of the number of pending messages. It is
>updated atomically together with changes to the pending buffers
>list.
> From the above it is clear that the counter will be out of sync with
>the inactive list between the beginning and the end of an enqueue or
>dequeue operation.
>In order to minimize interrupt latency, RTEMS disables interrupts
>only when adding and removing buffers from lists, but not throughout
>the whole enqueuing/dequeuing operation. Instead, it disables the
>scheduler during these operations, but this doesn't prevent
>interrupts.
>This means that the inconsistency between number_of_pending_messages
>and the inactive list can be observed from an interrupt handler if
>enqueuing or dequeuing is in progress.
>_CORE_message_queue_Submit checks whether there is still room in the
>queue by reading number_of_pending_messages. If there is room, it
>then calls _CORE_message_queue_Allocate_message_buffer to obtain a
>free buffer.
>Given that number_of_pending_messages and the list of inactive
>buffers can disagree, e.g., if _CORE_message_queue_Seize or another
>_CORE_message_queue_Submit is executing concurrently,
>_CORE_message_queue_Allocate_message_buffer may fail to obtain a
>free buffer despite the prior test.
>_CORE_message_queue_Allocate_message_buffer can detect a lack of
>free buffers and indicates it by returning a NULL pointer. Checking
>whether NULL has been returned instead of a buffer is optional and
>depends on RTEMS_DEBUG.
>If no check is performed, _CORE_message_queue_Submit will then try
>to use the buffer. In the absence of hardware detecting the
>de-referencing of NULL pointers, the wounded system will limp on a
>little further until, at least in the case of M1, it finally hangs
>somewhere.
>The patch below avoids the problem in the scenario described above
>by not using number_of_pending_messages as an indicator of whether
>free buffers are available, but by simply trying to get a buffer,
>and handling the result of failure.
>This is similar to how _CORE_message_queue_Seize works.
>Another possibility would be to make testing of the_message no
>longer optional. But then, there would basically be two tests for
>the same condition, which is ugly.
>- Werner
>_______________________________________________
>http://lists.milkymist.org/listinfo.cgi/devel-milkymist.org
>IRC: #milkymist at Freenode
>rtems-users mailing list
>rtems-users at rtems.org
>http://www.rtems.org/mailman/listinfo/rtems-users
