_Chain_Is_first/last overshoot
Thu Nov 10 20:28:30 UTC 2011
I don't see any uses of these functions in any test cases. Since they
are inline routines they probably aren't tripping any of the coverage
'uncovered' ranges?
The analysis seems to be correct. Right now these functions return
true if the passed node is the control block, whereas the intention
seems to be the functions should return true if the passed node is the
first node after the head (rsp last node before the tail).
I think this is a bug (and probably an old one) and I doubt the
functions themselves see much use. Most chain examples iterate through
by calling _Chain_First and continuing until !_Chain_Is_tail().  A
simple way to test for the bug and to add a new test case would be to
write some code that checks if _Chain_Is_first( _Chain_First(
control_node ) ) ) on a non-empty chain.
On Wed, Nov 9, 2011 at 3:10 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 11/9/2011 1:56 PM, Sébastien Bourdeauducq wrote:
>> -------- Original Message --------
>> Subject: [Milkymist-devel] [PATCH, tentative] RTEMS:
>> Date: Wed, 9 Nov 2011 16:53:53 -0300
>> From: Werner Almesberger<werner at almesberger.net>
>> Reply-To: Milkymist One, Milkymist SoC and Flickernoise developers' list
>> <devel at lists.milkymist.org>
>> Doubly-linked lists ("chains") in RTEMS have a "control" block that
>> looks like the next/prev link pair in an element. The list elements
>> link both ways to this control block.
>> _Chain_Is_first and _Chain_Is_last only probed if the link to the
>> next element - which would be the control block - is non-NULL.
>> Telling by the function description and given that there are already
>> functions called _Chain_Is_head and _Chain_Is_tail (which could be
>> simplified), this is probably not the intended behaviour.
>> This also affects the aliases rtems_chain_is_first and
>> rtems_chain_is_last.
>> These functions are not used a lot and I haven't seen any immediate
>> effect on M1 after changing them, so I can't say whether this patch
>> may unearth other problems.
> This needs a careful, careful review.  And a look at the history.
> I think by definition your change is right.  This is technically checking
> that the_node
> is permanent head or tail -- not checking that it is really the first or
> last real node
> on the chain.
> Can someone pitch in and help review where this is used?
> --joel
>> - Werner
>> Index: cpukit/score/inline/rtems/score/chain.inl
>> RCS file: /usr1/CVS/rtems/cpukit/score/inline/rtems/score/chain.inl,v
>> retrieving revision 1.23
>> diff -U 4 -r1.23 chain.inl
>> --- cpukit/score/inline/rtems/score/chain.inl   25 Nov 2010 11:48:11
>> -0000   1.23
>> +++ cpukit/score/inline/rtems/score/chain.inl   9 Nov 2011 19:42:13 -0000
>> @@ -296,9 +296,9 @@
>>   RTEMS_INLINE_ROUTINE bool _Chain_Is_first(
>>     const Chain_Node *the_node
>> -  return (the_node->previous == NULL);
>> +  return the_node->previous->previous == NULL;
>>   /** @brief Is this the Last Node on the Chain
>> @@ -313,9 +313,9 @@
>>   RTEMS_INLINE_ROUTINE bool _Chain_Is_last(
>> -  return (the_node->next == NULL);
>> +  return the_node->next->next == NULL;
>>   /** @brief Does this Chain have only One Node
>> http://lists.milkymist.org/listinfo.cgi/devel-milkymist.org
>> IRC: #milkymist at Freenode
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
