MVME162 BSP Status - Fixed
Hoover, Victor P CTR NAVAIR, AIR 4.1.3.3
victor.hoover.ctr at navy.mil
Thu Nov 10 22:02:59 UTC 2011
Okay, I've created a bug report (bug 1962) and I've attached updates for the
mvme162/ChangeLog file and a diff patch against RTEMS 4.10.1.
This is my first bug report and patch so I hope I got everything right.
And as for the user vs. developers list thread; well looks like I've gone from
user to developer in about a week.
- Vic Hoover
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Saturday, November 05, 2011 17:00
> To: Hoover, Victor P CTR NAVAIR, AIR 4.1.3.3; rtems-users at rtems.org
> Subject: Re: MVME162 BSP Status - Fixed
> Awesome! Please file a report with patch via Bugzlla
> (rtems.com/bugzilla) for review and merger.
> --joel
> "Hoover, Victor P CTR NAVAIR, AIR 4.1.3.3" <victor.hoover.ctr at navy.mil>
> wrote:
> >It looks like I've got the 162 BSP fully working now.
> >Code changes needed were:
> >console/console.c
> >- One line fix to char_ready() function
> >- I also added a quick and dirty printk() that works through
> /dev/console
> > once it's initialized (now that I've fixed some other stuff I can go
> > back and modify this to also work before the console is set up).
> >startup/bspstart.c
> >startup/bspclean.c
> >- Both of these had incorrect assumptions about the location of the
> 162Bug
> > vectors.
> >make/custom/mvme162.cfg
> >- Had to add -msoft-float to CPU_CFLAGS (varies by board model)
> >- Changed RTEMS_CPU_MODEL from 68040 to 68lc040 (varies by board
> model)
> >I've test with the following programs from testsuites/samples and all
> ran
> >successfully.
> >- base_sp
> >- capture
> >- fileio
> >- hello
> >- loopback
> >- ticker
> >- unlimited (created 513 tasks)
> >The paranoia example ran successfully up until it displayed the "END
> OF PARANOIA TEST"
> >message. After that it caused an F-Line exception.
> >Now I need to get network support added to the BSP and I'll be ready
> to go.
> > - Vic Hoover
Type: application/x-pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20111110/46347890/attachment.bin>
