Queue deletion hangs: SOLVED!
Gabriel Raineri
graineri at invap.com.ar
Fri Nov 11 13:10:23 UTC 2011
I have managed to get to the root of the matter...
The thing is, as you may expect... silly. :S
TASK A: Task waiting at the queue. Priority: X
TASK B: Task deleting the queue. Priority: X + 1
Task A has a infinite loop, sort of:
while (TRUE)
if (rtems_message_queue_receive(...) == RTEMS_SUCCESSFUL)
// Stuff
So, when TASK B deletes the queue, there is context switch and the CPU
is taken over by TASK A which will not yield the processor since the
call to rtems_message_queue_receive is no longer blocking.
End of the issue. =)
Thanks a lot!
Cheers,
Gabriel
On 11-Nov-11 8:47 AM, Gabriel Raineri wrote:
> Well, I wasn't able to figure out why the task hangs when its priority
> is lower than the one waiting at the queue.
> Providing you with a Test Case may take some time. So, I will try some
> other ideas in mind and if that doesn't solve the problem, I guess I
> will leave it for later.
> Thanks!
> On 10-Nov-11 11:32 AM, Gabriel Raineri wrote:
>> Quick update!
>> If I raise the priority of the task deleting the queue to be higher
>> than the one waiting, it works correctly.
>> I'll keep you posted.
>> Thanks!
>> On 10-Nov-11 10:33 AM, Gabriel Raineri wrote:
>>> Actually, I don't have a test case. However, I will try to write one
>>> to see if I can repeat the issue.
>>> Sorry, the RTEMS version is: 4.9.99.0
>>> Thanks again!
>>> On 10-Nov-11 10:25 AM, Joel Sherrill wrote:
>>>> On 11/10/2011 07:11 AM, Gabriel Raineri wrote:
>>>>> Hi everybody!
>>>>> I'm having an issue while deleting a queue: the call to
>>>>> rtems_message_queue_delete hangs.
>>>>> I have been debugging RTEMS code and I found that it gets stuck at
>>>>> _Thread_Enable_dispatch() in msgqdelete.c
>>>> Do you have a test case? This case is covered in the test suite
>>>> so there must be something different about your case.
>>>>> More details:
>>>>> - RTEMS Version: 4.99
>>>> That's not an RTEMS version number. What version are you using?
>>>> How did you get it?
>>>>> - The task that deletes the queue is not the one that created it.
>>>>> - There is a task blocked waiting for the queue which has a higher
>>>>> priority than the task deleting the queue.
>>>>> - I have also tried disabling interrupts before the deletion in
>>>>> order to avoid context switching with no luck (still hangs).
>>>>> - There are no pending messages on the queue.
>>>>> - All nodes are LOCAL.
>>>>> You might be wondering why in the world I'm trying to delete a
>>>>> queue. Well, to make a long story short, the idea behind this is
>>>>> to inject errors into our application to see if it is reacting as
>>>>> expected.
>>>>> Any help will be appreciated!
>>>>> Thanks in advance!
>>>>> Cheers,
>>>>> Gabriel
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20111111/e073901e/attachment.html>
