Ethernet PHY drivers
John Teller jsteller at spottydog.us
Sat Nov 26 16:41:55 UTC 2011
Hi,
I'm mucking about with Blackfin networking stuff and was able to get the
Ethernet driver running on a BF527.  At this point it only talks to the
PHY using the basic IEEE register set, which is OK for getting the board
up and running.  Unfortunately, all the good stuff like interrupt
generation on link changes etc. are in the extended vendor-specific area.
After looking around the 4.10 codebase, I see that every architecture
has its own PHY drivers, which are pretty much tied into the
architecture's built-in PHY, or a small subset of available parts.
I've also worked with uClinux on the Blackfin, where the PHY drivers are
separate from the MAC.  It's a big and complicated system, very much
overkill for what I believe RTEMS is aimed at, namely a small embedded
system with a predefined hardware configuration.  Politics and licensing
aside, there is still plenty in there to be learned from.
Are there any projects afoot to add a subset of this kind of
functionality?  If not, I'm willing to give it a go.
---JST
