PR1841 was Re: pending PRs
Tue Nov 29 16:36:42 UTC 2011
Please provide a patch.  The description is clear but if you have this
fixed already, then a patch is a much safer way to get it resolved
in the source.
--joel
On 11/27/2011 11:19 AM, Gedare Bloom wrote:
> On Sun, Nov 27, 2011 at 11:16 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com>  wrote:
>> On 11/27/2011 05:06 AM, Sébastien Bourdeauducq wrote:
>>> On 11/26/2011 07:29 PM, Gedare Bloom wrote:
>>>>> And these might require a little more time:
>>>>> * https://www.rtems.org/bugzilla/show_bug.cgi?id=1961 Race condition
>>>>> when
>>>>> using rtems_message_queue_send in ISR
>>>> Is there a test case that is useful to trigger the bug?
>>> Run Flickernoise and hammer the mouse/MIDI controls :-)
>> That sounds like fun. :)
>>>>> * https://www.rtems.org/bugzilla/show_bug.cgi?id=1841 Incorrect
>>>>> processing
>>>>> of DNS info from DHCP
>>>> I don't see any patches, so I guess this bug needs some discussion?
>>> No, there's no patch, but it should be a very simple change.
>> This needs a PR filed and an explanation.  If the change is simple,
>> just attach to the PR.  It sounds like it may need to go on older
>> branches.
> The PR is 1841
>> --joel
>>> Thanks,
>>> Sébastien
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D.             Director of Research&  Development
