tracing tools
Chris Johns
chrisj at rtems.org
Thu Nov 3 22:37:35 UTC 2011
On 4/11/11 3:34 AM, Xavier Raynaud wrote:
> I just started to investigate around trace tools available for RTEMS.
Great.
> Of course, I had a look at
> http://www.rtems.org/wiki/index.php/RTEMS_Trace_Tool (and
> http://code.google.com/p/rtems-tracing), but the status of this tool is
> not clear (and the wiki page said to contact Chris Johns for further
> details - here I am).
> My questions are:
> - What's the status of this tool ?
We have a number of parts that show the approach is sound and will work.
The remainder of the work is to get the code together, fix bugs,
performance issues or design holes, and to bring it up to the latest
RTEMS code and integrate it into the HEAD.
The trace tool can serve a couple of needed functions. The first is a
debug aid to see why something happens. Your target deadlocks. You have
a few task lists, the various objects but what is of interesting is the
sequence of event that lead to this. The second function is to verify
your code. You run various tests of pieces of your code and you verify
the input and out put data matches. This last need drives a basic
requirement of being able to take an executable and trace it.
> - How it works ? As far as I understand, it's an instrumentation at
> source level, with function wrapping. Am I right ?
There are 3 parts (I think; it has been a while):
1. Configuration, definition and post link processing.
2. Target runtime and capture.
3. Post processing and analysis.
The configuration, definition and post link processing is first a
definition of the functions you wish to trace and taking that definition
to create a suitable set of wrapper functions to link against a known
working executable RTEMS image. The approach is to use the GNU linker's
wrap option. The ld man page has the details. The idea is to rename a
function of interest to another name and then provide a function with
the same name and finger print that captures data on the way in and/or
way out. The ld wrap option does the rename and we do the rest. We read
the debug data from the ELF file to determine the function signature to
allow us to generate a suitable wrapper function. The requirement is to
trace a existing executable with out changing any of the code or
libraries used. We can instrument the code with wrapper functions and
runtime trace support just not change the code being traced. This means
we may not have access to the headers and compile time defines to know
the exact signature of a function therefore the debug data is used. The
wrapper function we generate needs to integrate into the run-time side
of the code present on the target. The types of things required is
runtime control for tracing a specific function's entry and exit in an
efficient way.
The second part of the puzzle is the target runtime support and data
capture. We need code on the target to manage the trace process. You may
wish to instrument a number of functions how-ever your debugging or
tracing may end up with only a few functions of interest being traced.
To support this we have runtime control of the entry and exit tracing of
every instrumented function. We also need a means of getting the data
off the target or saved which is fast enough to handle the amount of
data that may be generated. The capture engine in the current code base
is an working example of this. It was features such as priority windows,
triggers and trace flags. The tracing needs to be interrupt safe and now
SMP safe.
Finally we need a suitable way of reporting the results that is useful
and meaningful. This includes a flexible way to extract the data from
the target.
As I said we have a number of these parts in various states of
development. What we need is someone to pick these up and complete the
work or to get the work completed via a support contract or contracts.
