conversion of the __inline__ and inline pragmas to RTEMS_INLINE_ROUTINE?
Ralf Corsepius
ralf.corsepius at rtems.org
Wed Nov 9 17:03:50 UTC 2011
On 11/09/2011 05:14 PM, Cudmore, Alan P. (GSFC-5820) wrote:
> A couple of questions:
> 1. Is it dangerous or not good practice to compile the RTEMS source and the application with different flags?
> ( the flags I listed earlier were for our applications only )
Depends.
-W.. flags are mostly harmless ("mostly", because can trigger hidden
bugs in gcc as well - Not very likely to happen but also not impossible).
The more agressive -W... flags you are using, the more likely gcc
produces "false warnings" and "stylish warnings". The problem here is to
separate "false" from "real" warnings[1]
-Werror is a means to pressurize developers. IMO, in combination with
hand-crafted/hand-selected -W... flags, it's suitable during certain
periods of development, but non-suitable as defaults.
All language-dialect changing flags (-ansi, -std=...) and
code-generation changing (typically -f.. and -0X) flags are potentially
dangerous.
That said, using different flags than defaults carries risks insofar as
they have seen less compilation-testing than the defaults.
Or conversely: If you are sufficently confident about your choice flags,
there isn't much wrong in using them.
> 2. Is RTEMS moving toward C99 compliance?
... yes, very slowly ... but the devil's in the details[2].
Ralf
[1] Real world example: GCC-4.6.x aggressively warns about "set but
unused variables". Recently having gone after these in RTEMS showed the
overwhelming majority of these warnings to be "false warnings", however
there were some real bugs hidden amongst them, older GCCs did not diagnose.
[2] RTEMS is not alone with this situation. Many other non-trivial
pieces of SW of considerable size are in a similar position.
(I haven't tried recently, but some time ago, not even the then-current
versions of binutils, gdb and GCC were c99 compliant).
