_Chain_Is_first/last overshoot
Gedare Bloom
gedare at rtems.org
Sat Nov 12 23:01:32 UTC 2011
I have filed PR1964 with both the testsuite change and the chain.inl patch.
Thanks,
Gedare
On Thu, Nov 10, 2011 at 3:59 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 11/10/2011 02:57 PM, Gedare Bloom wrote:
>> Attached patch breaks with CVS head, showing that our current
>> implementation of Chain_Is_first contradicts _Chain_First.
> Thanks Gedare. I think this needs a PR and both
> this change and the test diff you have need to be
> applied.
> --joel
>> On Thu, Nov 10, 2011 at 3:28 PM, Gedare Bloom<gedare at rtems.org> wrote:
>>> I don't see any uses of these functions in any test cases. Since they
>>> are inline routines they probably aren't tripping any of the coverage
>>> 'uncovered' ranges?
>>> The analysis seems to be correct. Right now these functions return
>>> true if the passed node is the control block, whereas the intention
>>> seems to be the functions should return true if the passed node is the
>>> first node after the head (rsp last node before the tail).
>>> I think this is a bug (and probably an old one) and I doubt the
>>> functions themselves see much use. Most chain examples iterate through
>>> by calling _Chain_First and continuing until !_Chain_Is_tail(). A
>>> simple way to test for the bug and to add a new test case would be to
>>> write some code that checks if _Chain_Is_first( _Chain_First(
>>> control_node ) ) ) on a non-empty chain.
>>> On Wed, Nov 9, 2011 at 3:10 PM, Joel Sherrill<joel.sherrill at oarcorp.com>
>>> wrote:
>>>> On 11/9/2011 1:56 PM, Sébastien Bourdeauducq wrote:
>>>>> -------- Original Message --------
>>>>> Subject: [Milkymist-devel] [PATCH, tentative] RTEMS:
>>>>> Date: Wed, 9 Nov 2011 16:53:53 -0300
>>>>> From: Werner Almesberger<werner at almesberger.net>
>>>>> Reply-To: Milkymist One, Milkymist SoC and Flickernoise developers'
>>>>> list
>>>>> <devel at lists.milkymist.org>
>>>>> To: Milkymist One, Milkymist SoC and Flickernoise developers' list
>>>>> Doubly-linked lists ("chains") in RTEMS have a "control" block that
>>>>> looks like the next/prev link pair in an element. The list elements
>>>>> link both ways to this control block.
>>>>> _Chain_Is_first and _Chain_Is_last only probed if the link to the
>>>>> next element - which would be the control block - is non-NULL.
>>>>> Telling by the function description and given that there are already
>>>>> functions called _Chain_Is_head and _Chain_Is_tail (which could be
>>>>> simplified), this is probably not the intended behaviour.
>>>>> This also affects the aliases rtems_chain_is_first and
>>>>> rtems_chain_is_last.
>>>>> These functions are not used a lot and I haven't seen any immediate
>>>>> effect on M1 after changing them, so I can't say whether this patch
>>>>> may unearth other problems.
>>>> This needs a careful, careful review. And a look at the history.
>>>> I think by definition your change is right. This is technically
>>>> checking
>>>> that the_node
>>>> is permanent head or tail -- not checking that it is really the first or
>>>> last real node
>>>> on the chain.
>>>> Can someone pitch in and help review where this is used?
>>>> --joel
>>>>> - Werner
>>>>> Index: cpukit/score/inline/rtems/score/chain.inl
>>>>> RCS file: /usr1/CVS/rtems/cpukit/score/inline/rtems/score/chain.inl,v
>>>>> retrieving revision 1.23
>>>>> diff -U 4 -r1.23 chain.inl
>>>>> --- cpukit/score/inline/rtems/score/chain.inl 25 Nov 2010 11:48:11
>>>>> -0000 1.23
>>>>> +++ cpukit/score/inline/rtems/score/chain.inl 9 Nov 2011 19:42:13
>>>>> -0000
>>>>> @@ -296,9 +296,9 @@
>>>>> RTEMS_INLINE_ROUTINE bool _Chain_Is_first(
>>>>> const Chain_Node *the_node
>>>>> - return (the_node->previous == NULL);
>>>>> + return the_node->previous->previous == NULL;
>>>>> /** @brief Is this the Last Node on the Chain
>>>>> @@ -313,9 +313,9 @@
>>>>> RTEMS_INLINE_ROUTINE bool _Chain_Is_last(
>>>>> - return (the_node->next == NULL);
>>>>> + return the_node->next->next == NULL;
>>>>> /** @brief Does this Chain have only One Node
>>>>> _______________________________________________
>>>>> http://lists.milkymist.org/listinfo.cgi/devel-milkymist.org
>>>>> IRC: #milkymist at Freenode
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.org
>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
