Mirroring Problem?
Ralf Corsepius ralf.corsepius at rtems.org
Mon Nov 28 04:30:10 UTC 2011
On 11/26/2011 03:23 PM, Joel Sherrill wrote:
> Hi,
> Looks like something isn't right on the Fedora 14 repo:
> Total download size: 3.7 M
> Downloading Packages:
> ftp://ftp.rtems.eu/pub/rtems/linux/4.11/fedora/14/i386/rtems-4.11-arm-rtems4.11-gcc-4.6.2-3.fc14.i686.rpm:
> [Errno 14] FTP Error 550 :
> Trying other mirror.
> http://www.rtems.info/ftp/pub/rtems/linux/4.11/fedora/14/i386/rtems-4.11-arm-rtems4.11-gcc-4.6.2-3.fc14.i686.rpm:
> [Errno 14] HTTP Error 404 :
> http://www.rtems.org/ftp/pub/rtems/linux/4.11/fedora/14/i386/rtems-4.11-arm-rtems4.11-gcc-4.6.2-3.fc14.i686.rpm:
> [Errno 14] HTTP Error 403 :
> Error Downloading Packages:
> rtems-4.11-arm-rtems4.11-gcc-4.6.2-3.fc14.i686: failure:
> rtems-4.11-arm-rtems4.11-gcc-4.6.2-3.fc14.i686.rpm from rtems-4.11:
> [Errno 256] No more mirrors to try.
> Any ideas?
Probably a mixed effect from several issues interacting:
Preliniary note: There was a huge upgrade of the rtems-4.11 toolchain
packages Wed-Fri last week.
1. As creation of the master repositories on rtems.org is not atomic and
can take many hours, there is a larger possibility for a mirror to go
out of sync with effects sneaking through to users, especially in
situations of mass-builds like this one.
2. The bandwidth, at least I had been observing when accessing rtems.org
on Thursday and Friday, had been fairly poor (Larger timeframes with <
50 bytes/sec). When checking the load on rtems.org, I found it being
busy and fairly loaded, but not beyond what I had expected.
3. Checking the contents of
ftp://ftp.rtems.eu/pub/rtems/linux/4.11/fedora/14/i386/ shows something
is wrong with this directory on rtems.eu.
Ralf
