Fwd: Different behaviour of RTEMS in QEMU/i386 and SPARC
Constantine "chicky" Giotopoulos
kotsosgiotopoulos at gmail.com
Mon Oct 31 11:04:59 UTC 2011
I used GCC 4.4.5 with the "-lm" option. In Qemu I use GCC 4.2.4.
Could it be a compiler issue?
On Mon, Oct 31, 2011 at 11:55 AM, Sebastian Huber <
> On 10/31/2011 11:50 AM, Constantine "chicky" Giotopoulos wrote:
>> The original program is not using any RTEMS directives, it's just a bunch
>> of
>> functions that execute floating point operations, that can be compiled
>> and run
>> on any machine with a compiler. The only option needed when compiling it
>> is
>> "-lm" because it utilizes the "math.h" library. Since its execution is
>> proceeding normally means that the CPU is able to handle the operations.
>> Even
>> if the CPU couldn't handle the operation, it would have presented
>> somekind of
>> "defect" of "flaw" message.
> Which GCC and GCC options do you use to compile it to run outside of Qemu?
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20111031/5fd5e343/attachment.html>
