Different behaviour of RTEMS in QEMU/i386 and SPARC
Till Straumann
strauman at slac.stanford.edu
Mon Oct 31 21:04:21 UTC 2011
You may want to try this with a lot of stack space - just
to exclude that it is a stack overflow issue
(since you created the task with minimum stack size)
- T.
On 10/31/2011 02:58 AM, Constantine "chicky" Giotopoulos wrote:
> Hello everyone.
> Using RTEMS 4.8.2, I create a single task that executes the code of
> "paranoia.c" (it is included when installing RTEMS 4.8.2 in the path
> .../rtems-4.8.2/testsuites/samples/paranoia/paranoia.c):
> rtems_task Init( rtems_task_argument ignored )
> rtems_status_code status; rtems_id id;
> //Create and start the first task
> status = rtems_task_create( rtems_build_name( 'T', 'A', '1', ' ' ), 1,
> RTEMS_MINIMUM_STACK_SIZE, RTEMS_DEFAULT_MODES,
> RTEMS_DEFAULT_ATTRIBUTES | RTEMS_FLOATING_POINT, &id);
> assert( !status );
> status = rtems_task_start( id, task1, 0 );
> assert( !status );
> status = rtems_task_delete( RTEMS_SELF );
> exit( 0 );
> rtems_task task1( rtems_task_argument ignored )
> paranoia();
> rtems_task_delete(RTEMS_SELF);
> Paranoia program contains a number of functions that perform floating
> point operations.
> When I execute the aforementioned code on a SPARC machine it works
> perfectly. But when I execute the same code using Qemu/i386 the
> execution halts when "Milestone 140" is reached, and more
> specifically after the line indicated bellow:
> Milestone = 140;
> printf ("\n");
> /* ...calculate Exp2 == exp(2) == 7.389056099... */
> X = Zero;
> I = 2;
> Y = Two * Three;
> Q = Zero;
> N = 0;
> do {
> Z = X;
> I = I + 1;
> Y = Y / (I + I);
> R = Y + Q;
> X = Z + R;
> Q = (Z - X) + R;
> while (X > Z);
> Z = (OneAndHalf + One / Eight) + X / (OneAndHalf * ThirtyTwo);
> X = Z * Z;
> Exp2 = X * X;
> X = F9;
> Y = X - U1;
> *_printf ("Testing X^((X + 1) / (X - 1)) vs. exp(2) = %.17e as X ->
> 1.\n", Exp2);_*
> for (I = 1;;) {
> Z = X - BInvrse;
> Z = (X + One) / (Z - (One - BInvrse));
> Q = POW (X, Z) - Exp2;
> if (FABS (Q) > TwoForty * U2) {
> N = 1;
> V9 = (X - BInvrse) - (One - BInvrse);
> BadCond (Defect, "Calculated");
> printf (" %.17e for\n", POW (X, Z));
> printf ("\t(1 + (%.17e) ^ (%.17e);\n", V9, Z);
> printf ("\tdiffers from correct value by %.17e .\n", Q);
> printf ("\tThis much error may spoil financial\n");
> printf ("\tcalculations involving tiny interest rates.\n");
> break;
> else {
> Z = (Y - X) * Two + Y;
> X = Y;
> Y = Z;
> Z = One + (X - F9) * (X - F9);
> if (Z > One && I < NoTrials)
> I++;
> else {
> if (X > One)
> if (N == 0)
> printf ("Accuracy seems adequate.\n");
> break;
> else
> X = One + U2;
> Y = U2 + U2;
> Y += X;
> I = 1;
> Milestone = 150;
> In other words, the program executes until the
> 1.\n", Exp2);_*
> but stops there. If I comment out the section of the code, the rest of
> the program executes normally.
> What could be the case for this behaviour? Why is the code running
> smootly on a SPARC but not on Qemu/i386 and how could I work out an
> explaination?
> Thank you in advance.
URL: <http://lists.rtems.org/pipermail/users/attachments/20111031/82f1eeb6/attachment.html>
