Task Creation Issue
Gabriel Raineri graineri at invap.com.ar
Thu Oct 6 17:07:57 UTC 2011
Solved!
I forgot to add:
#define  CONFIGURE_MESSAGE_BUFFER_MEMORY \
    CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( _maxQ1, _sizeQ1) + \
    CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( _maxQ2, _sizeQ2) + \
Thanks everybody!
Cheers,
G.
PS: Dumb, dumb, dumb...
On 06-Oct-11 1:06 PM, Joel Sherrill wrote:
> On 10/06/2011 10:53 AM, Gedare Bloom wrote:
>> Is it possible that you underallocated something other than tasks?
>> All those configure commands reserve some space in a shared
>> workspace, and if for example you have timers or more than 21
>> semaphores then the workspace could be too small.
>> Another possibility is a bug in confdefs.h where the workspace size
>> is calculated. We would need more info to diagnose further, including
>> how you ./configure RTEMS and some idea of the resources your code uses.
> This is sadly always a possibility.  All it takes is missing one
> allocation
> on task create.
> If you can put together a VERY simple test case with nothing but tasks
> that does it, we can file a PR and I can look into it.
> --joel
>> On Oct 6, 2011 11:04 AM, "Gabriel Raineri" <graineri at invap.com.ar
>> <mailto:graineri at invap.com.ar>> wrote:
>> > Hi everybody!
>> > I'm having an issue when creating tasks. The thing is that I'm
>> receiving
>> > RTEMS_UNSATISFIED (not enough memory for stack/FP context) after
>> having
>> > created a bunch of them.
>> > Let's dig into the details...
>> > #define CONFIGURE_MAXIMUM_TASKS 25
>> > #define CONFIGURE_MAXIMUM_SEMAPHORES 21
>> > #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 14
>> > #define CONFIGURE_MAXIMUM_PARTITIONS 6
>> > #define CONFIGURE_MAXIMUM_TIMERS 0
>> > #define CONFIGURE_MAXIMUM_BARRIERS 1
>> > * Tasks are being created after all other RTEMS objects (Semaphores,
>> > Queues, etc.).
>> > * After creating the task #22 and when attempting to create task #23 I
>> > get the aforementioned error code.
>> > * All tasks are created with a stack size of
>> RTEMS_MINIMUM_STACK_SIZE bytes.
>> > The weird thing is that if I define CONFIGURE_EXTRA_TASK_STACKS to be
>> > RTEMS_MINIMUM_STACK_SIZE * 5 (20480 bytes) the tasks are created
>> without
>> > any problem.
>> > I think I shouldn't need to define CONFIGURE_EXTRA_TASK_STACKS. Am
>> I right?
>> > Am I missing something?
>> > Any help will be appreciated!
>> > Cheers,
>> > Gabriel
URL: <http://lists.rtems.org/pipermail/users/attachments/20111006/bfcc4873/attachment-0001.html>
