rtems gcc 4.6.1 can not compile stop at check TLS
Xiangfu Liu xiangfu at sharism.cc
Wed Sep 7 07:43:04 UTC 2011
thanks Ralf
I will re-compile my toolchain and test.
On 09/06/2011 07:03 PM, Ralf Corsepius wrote:
> On 08/29/2011 11:45 PM, Sebastien Bourdeauducq wrote:
>> On Mon, 2011-08-29 at 16:27 -0500, Joel Sherrill wrote:
>>> + Is this a reasonable and meaningful set?
>>> /opt/rtems-4.11/lm32-rtems4.11/lib/mmultiply-enabled/libc.a
>>> /opt/rtems-4.11/lm32-rtems4.11/lib/mmultiply-enabled/mbarrel-shift-enabled/libc.a
/opt/rtems-4.11/lm32-rtems4.11/lib/libc.a
>>> /opt/rtems-4.11/lm32-rtems4.11/lib/mbarrel-shift-enabled/libc.a
>> As far as we are concerned, we only need:
>> mbarrel-shift-enabled/mmultiply-enabled/mdivide-enabled/msign-extend-enabled
> I've added a patch implementing this to today's/yesterday's update of
> the lm32-rtems4.11 toolchains. Shouldn't somebody complain or this
> trigger bugs somewhere, I intend to propagate this change into
> upstream GCC-4_5-branch/4_6-branch and trunk in near future (say, end
> of this month).
