RES: Multiprocessing
Wendell Pereira da Silva
wendell.silva at compsisnet.com.br
Tue Sep 20 19:15:49 UTC 2011
Hi Asma,
I can give you an example from the application point of view. So this answer is limited. Maybe other ones can help more.
You can find Multiprocessing examples in the RTEMS test suite which is the RTEMS source code.
Have a look at rtems/testsuites/mptests. This directory contains all the MP (MultiProcessing) tests and can be useful as a starting point.
Att.
Wendell.
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de Asma Mehiaoui
Enviada em: terça-feira, 20 de setembro de 2011 15:58
Para: rtems
Assunto: Multiprocessing
Hello rtems-users
Can someone give me an example for using multiprocessing on RTEMS?
Best ragards
URL: <http://lists.rtems.org/pipermail/users/attachments/20110920/54aaaaf3/attachment.html>
