WatchDog
Eduardo Esteban
eaestebanb at gmail.com
Wed Sep 21 09:56:50 UTC 2011
What I am trying to do is the following:
Obtain the Timeout;
Kick the OBC watchdog.
Set the OBC watchdog's timeout.
Stops the Watchdog resetting from the OBSW.
Triggers a SW reset.
Thanks in advance,
Best regards,
Eduardo
On 15 September 2011 16:20, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 09/15/2011 06:18 AM, Sebastian Huber wrote:
>> On 09/15/2011 11:25 AM, Eduardo Esteban wrote:
>>> Anybody can send me an example of a watchdog? I do not understand how it
>>> works.
>>> Thanks in advance.
>> Usually the dog barks and the thief runs away.
>> Feeling feisty this evening Sebastian? :D
> There are no watchdogs in the RTEMS public API.
> There are two types of watchdogs you see in
> RTEMS systems:
> + hardware watchdogs - typically reset hardware
> if you don't pet them periodically.
> + software watchdogs - internal RTEMS object
> used to build public services. You should
> never use these directly.
> What are you trying to do?
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20110921/762a29f2/attachment.html>
